Communication between M340 and Cube20 I/O module with Ethernet/IP
  • Industrial Automation
  • Communication between M340 and Cube20 I/O module with Ethernet/IP
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Kik
Crewman Kik
Crewman
Posted: ‎2025-03-10 04:22 AM
1326
Hello all,
I'm a french student working on a project. I bought a M340 PLC with at least a NOC0401 on it.
The PLC is working, I've set a IP@ on it.
I also have a Cube20 BN-E/IP DI8 module, working with Ethernet/IP protocol.
Both have IP@ on the same network. From my laptop, I can ping both.
Now I'm trying to read inputs from my Cube20 on my PLC.
I added it in the "DTM Browser" as Generic EDS Device DTM and configured IP@. I'm able, from the DTM Browser on Control Expert to "Connect" to the Cube20 (right clic on it and CONNECT).
I don't know what to do from now. Any suggestion ?
In advance, thanks
  • Process Automation Talks
ciupol
Lt. Commander ciupol
Lt. Commander
Posted: ‎2025-03-10 12:32 PM
1
1298
Do get the implicit data exchange going you have to configure IO instances and data sizes. Double click your generic DTM in DTM browser and you should see screen similar to the attached screenshot. You need to configure what I highlighted in yellow. You get that information from device manual. I am looking at file 56005_hdb_e_16.pdf downloaded from Murr Electronic website. On page 25 it gives you instance numbers and starting on page 22 it tells you how to obtain data size. Once you set it up you should be good to go and you see data in your device DDT.
Replies 4
ciupol
Lt. Commander
1
1299
Kik
Crewman Kik
Crewman
Posted: ‎2025-03-12 02:20 PM
In response to ciupol
Hi Ciupol. Thank you so much for your help, I managed to read the inputs with your help and the doc.
Now I'm wondering how to use this information, because I see that the same variable ("Cube20_IN.Free0[0]") changes depending on which input is activated as you can see on my screenshots.
If I activate input 1, value is 1. Input 2, value 2. Input 3, value 4. Input 4, value 8 and so one...
Do you know if this is the expected behavior?
ciupol
Lt. Commander
Posted: ‎2025-03-19 05:46 AM
1
1151
Kik, yes it absolutely makes sense. Bit 0 of Cube20_IN.Free0[0] Byte is status of input 1, bit 1 of Cube20_IN.Free0[0] Byte is status of input 2 etc. In your animation table display numbers as binary (right click on variable number and select Display format -> Binary) and it will be obvious for you what is going on. Again you have to use manual for your module. Look specifically in sections 4.5 and 6.1 of manual mentioned in my previous post.
Kik
Crewman Kik
Crewman
Posted: ‎2025-03-21 01:09 PM
Thank you very much once again
