Cicode help
  • Industrial Automation
  • Cicode help
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
OsamaSalih
Lieutenant JG OsamaSalih
Lieutenant JG
Posted: ‎2022-01-18 03:35 AM
2680
Cicode help
Hi Everyone
I am looking for a Cicode code that sets an Excel file name to current date (month-day-year)
can anyone help ?
Osama
  • Smart Design & Engineering
RobertSanders
Lt. Commander RobertSanders Lt. Commander
Lt. Commander
Posted: ‎2022-01-19 09:11 AM
3
2670
I have created two cicode functions in the attached text file, simply copy into the cicode editor
Call the function SetFileNameToDate(""C:\Temp\DataLog.xlsx"") with the file that needs changing as the argument.
In the example above the file will be renamed to something like this C:\Temp\01-19-2022.xlsx.
I have not implemented any form of error checking, Eg if the file 01-19-2022.xlsx already exists etc..
Regards
Rob
Replies 4
RobertSanders
Lt. Commander
3
2671
Regards
Rob
OsamaSalih
Lieutenant JG
Posted: ‎2022-01-22 09:39 AM
In response to RobertSanders
2654
HI Rob
thank you for your reply
I need to have more details about how to call the function
with correct syntax
Regards
Osama
RobertSanders
Lt. Commander
Posted: ‎2022-01-24 01:32 AM
In response to OsamaSalih
2649
You simply call the function and pass the Excel file name and path that you want to change Eg
SetFileNameToDate("C:\Temp\DataLog.xlsx")
The Excel File will be renamed to mm-dd-yyyy.xlsx .  If you want to call the function by a button on a screen just copy the above into Up Command and change the path and file name to match.
Regards
Rob
OsamaSalih
Lieutenant JG
Posted: ‎2022-01-24 06:20 AM
Thank you @RobertSanders
The code you provided worked just perfect
Regards
Osama
