Change vertically filling range of a rectangle
  • Industrial Automation
  • Change vertically filling range of a rectangle
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
EcoStruxure™ Operator Terminal Expert 3.1
Harmony HMI
jhonut
Ensign jhonut
Ensign
Posted: ‎2021-02-15 04:01 AM . Last Modified: ‎2021-02-15 04:03 AM
3011
I have a rectangle which has to be vertically filled depending on an analogue value. Rectangle's default filling range is 0-100. I couldn't find any setting in Fill level section where to change this range.
I thought that Vertical scale value is what I need to change, but I was wrong. Instead of 0-100, I need 0-50. Can, please, anybody tell me how can I change this range?
Many thanks in advance!
  • Smart Design & Engineering
  • Training
Paul_Derbyshire
Ensign Paul_Derbyshire Ensign
Ensign
Posted: ‎2021-02-15 05:38 PM . Last Modified: ‎2021-02-15 06:30 PM
2
2999
Hello @jhonut ,
Sounds like a great use case for a scale converter.    The vertical fill is always 0-100%.
Create a scale converter with a source range of 0-50.  Output Range of 0-100.
When selecting the variable for fill animation, turn on the converter check box, choose "One Way", and select the scale converter you created.
Here is a link to a sample project: Vertical Fill Animation - Scale Converter for Custom Range.vxdz
Let me know if this method works for you.
Paul Derbyshire
Senior Product Application Expert | Sales Enablement | HMI Line of Business, Digital Factory | Industrial Automation Business | Schneider Electric
  • Fill Animation
  • Scale Converter
Paul_Derbyshire
Ensign
2
3000
Hello @jhonut ,
Paul Derbyshire
  • Fill Animation
  • Scale Converter
jhonut
Ensign jhonut
Ensign
Posted: ‎2021-02-16 01:50 AM
In response to Paul_Derbyshire
2985
@Thanks for your solution, @Paul_Derbyshire! This is exactly what I was looking for!
Paul_Derbyshire
Ensign
Posted: ‎2021-02-16 04:41 AM
In response to jhonut
@jhonut When you have a moment please mark my answer as the solution.
Thank you!
Paul Derbyshire
