Challenge with Lexium Integrated Drive :ILE1B661S2203.
  • Industrial Automation
  • Challenge with Lexium Integrated Drive :ILE1B661S2203.
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Rahul054
Rahul054
Cadet
Posted: ‎2025-07-21 04:25 AM
We are currently working with an S7-300 CPU setup where a Schneider Lexium Integrated Drive (Model Number:ILE1B661S2203)  is connected via PROFIBUS. At the moment, we are facing an issue with the Schneider motor and would like to configure it using Schneider’s Lexium software.
We have the Lexium software installed on our Programming Device (PG). The main PROFIBUS cable is currently connected to the X1 port of the CPU. To perform the configuration, I plan to switch the CPU to STOP mode and connect the PG to the X2 port, and then access the motor via the Lexium software.
Before proceeding, I would appreciate your assistance in verifying the following:
How can I confirm that the correct MPI/PROFIBUS driver is installed on my PG?
If the driver is not present or outdated, could you kindly guide me on how to download and install the correct one?
I also have an USB to RS485 (B) connector available.
Thank you
  • Process Automation Talks
Replies 0
