Posted: 2022-09-16 03:03 AM
Hello everyone,
Newbie with regards to Altivar devices. Working with an ATV340. I cannot seem to connect to it. I have downloaded and installed the ATV340 DTM.
I dont have a USBA-RJ45 cable, so I used a USB-DB9 converter/null modem cable/DB9-RJ45 to CN7 port.
SoMove detects USB converter, but doesnt see the drive.
I tried to see if I could connect through to the Ethernet port, but dont have the IP address of the drive. I do have the MAC address though.
Any assistance would be appreciated.
I went through the documentation and videos, and cannot seem to find instructions on how to connect via Ethernet without IP address.
@SoMove @ATV340
Posted: 2022-09-16 03:13 AM
If you are unsure about the IPV4 address, you can always use IPV6 to connect to the drive and update the IPV4 address.
Please see the video for more information
Posted: 2022-09-18 06:12 PM
Hi @EASI-JohnB,
Please find attached file for Modbus serial Communication of ATV340 (embedded).
also you can download from this link below.
https://www.se.com/ww/en/download/document/NVE61654/
Please make sure that you are using RS232 (USB or db9) - RS485 (RJ 45) converter, because on ATV340 is using RS485 Modbus serial.
regards,
Posted: 2022-09-19 10:37 AM
thanks...it worked at first attempt.
I had to have been doing something wrong.
