Can I change the default save location path in Machine Expert?
  • Industrial Automation
  • Can I change the default save location path in Machine Expert?
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Yelper85
Ensign Yelper85
Ensign
Posted: ‎2024-06-03 02:14 AM
Hi all,
Currently Machine Expert wants to save all new projects to my 'Document' folder. I don't want that.
I assumed/hoped it was merely a simple case of pointing the system to the desired directory in options, however this doesn't appear to be available.
You can change the library and device repository location from options, but seemingly not the default save location. Is that correct? If so, is there a workaround?
  • Smart Design & Engineering
Replies 0
