Bytes Swapping
  • Industrial Automation
  • Bytes Swapping
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
islam_said
Crewman islam_said
Crewman
Posted: ‎2024-07-29 02:29 AM
1484
Bytes Swapping
I am looking for a Function can Swap Bytes of INT or DINT
AB => BA
or
ABCD => DCBA
Is there a function that can do this except for SWAP_ARINT, SWAP_ARWORD, as these are using Arrays
  • Process Automation Talks
  • Smart Design & Engineering
AdrianCiobanu
Ensign AdrianCiobanu
Ensign
Posted: ‎2024-07-29 06:58 AM
Here are some function from OSCAT libraries that you can adapt for what you need.
FUNCTION SWAP_BYTE : WORD
VAR_INPUT
                IN : WORD;
END_VAR
SWAP_BYTE := ROL(in,8);
FUNCTION SWAP_BYTE2 : DWORD
VAR_INPUT
                IN : DWORD;
END_VAR
SWAP_BYTE2 := (ROR(in,8) AND 16#FF00FF00) OR (ROL(in,8) AND 16#00FF00FF);
AdrianCiobanu
Ensign
VAR_INPUT
                IN : WORD;
END_VAR
VAR_INPUT
                IN : DWORD;
END_VAR
Bastian_Schmitz
Admiral
Posted: ‎2024-07-29 10:15 AM
Which PLC did you use, if the PLC support ST the example from Adrian should work fine.
