Posted: 2021-12-01 01:23 PM
I hope I writing topic in correct forum segment.
I have to bind 2 networks together - 1 is based on BACnet and 2nd is Infinet (Andover Controls with Continuum - old system).
Now working on best solution for that - found so far that bCX1-R(CR) can do this job - to make communication possible over the Ethernet TCP/IP & BACnet/IP.
Is there any solutions to integrate two networks together at the workstation? Like to install/configure software and let say to run Continuum and see BACnet devices or let say to run Niagara and pull Infinet devices?
Any thoughts would be appreciated.
Thank you!
Posted: 2021-12-02 08:31 AM
Hello Andrew,
The first solution that comes to mind is HMS, they have a lot of protocol converters.
Kind regards
Martyn
PLC-Easy Simply Un-Mazing Automation
Posted: 2021-12-02 10:32 AM
Hey Martin,
What is the "HMS" - never heard about it.
Could you give little more details please - their website, info etc?
Thank you!
Posted: 2021-12-02 10:39 AM
Hello Andrew,
I don't think I can put a web link in the message, but if you go to www dot anybus dot com, you will find many protocol converters.
Kind regards
Martyn
Posted: 2021-12-02 07:51 PM
Hey Martyn,
Thank you for this source - these guys really specializing on different converting/routing but seems like they left Infinet (Andover Controls) behind unfortunately.
I have to keep looking.
Posted: 2021-12-02 08:08 PM
Hello Andrew
EcoStruxure Building Operation is exactly what you need, it supports both Infinet and BACnet.
