BACnet COV Notification Issue
Send InviteCancel
Posted: 2024-12-0809:10 PM
I am using M172 HVAC controller and Enabled the BACnet in my system. I was using COV property of BACnet, I encountered the issue with notification. I use to send subscription through Yabe and VTS. But the PLC is sending notification with any value change. and even it not presubscribing the object and I am using only analog input for COV subscription. I have also added the value in COV increment.
