Array of bytes to string
  • Industrial Automation
  • Array of bytes to string
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
Modicon M340
EcoStruxure™ Control Expert
Olofsson
Crewman Olofsson
Crewman
Posted: ‎2022-09-11 01:51 PM
5932
Hi !
I have a array of bytes that I would like to convert to a string in Control Expert. Each byte holds an ASCII code of a letter or a number. This seemingly basic operation has proven a bit more tricky than I expected. Actually, I have not found a solution I'm happy with.
On possible solution is to define a string with the same memory address as the array. However, the idea is to write a somewhat portable program unit and I would like to avoid direct memory addressing.
There have to be a correct and simple way to do this. Help would very much be appreciated !
  • Training
RaviNayak
Ensign RaviNayak Ensign
Ensign
Posted: ‎2022-09-11 10:46 PM
1
5911
@Olofsson  Please find the attached PDF for the information on the conversion,  hope this helps.
RaviNayak
Ensign
1
5912
Olofsson
Crewman Olofsson
Crewman
Posted: ‎2022-09-12 02:31 AM
In response to RaviNayak
Thanks RaviNayak !
It's close enough, Not the most elegant code but it will do. For my 46 byte array bytes_recu I get.
  FOR i := 1 TO 23 DO
    int_recu[i] := BYTE_TO_INT(bytes_recu[i*2])+SHL(IN := BYTE_TO_INT(bytes_recu[i*2-1]), N := 8);
  END_FOR;
  string_recu := ASCII_TO_STRING (int_recu);
For something that should be a simple conversion it sure is a lot of operation for nothing.
