ATV71 LI1-6 digital inputs
  • Industrial Automation
  • ATV71 LI1-6 digital inputs
Bastian_Schmitz
35
LeTomas
14
JerryBartlemay
7
PSCrane
PSCrane
Cadet
Posted: ‎2024-08-07 04:21 AM
429
Hiya,
Is there a way to set the following:
LI1 - Fast Forward
LI2 - Slow Forward
LI3 - Slow Reverse
LI4 - Fast Reverse
The inputs will be from sensors so as a unit hits a sensor, it will then feed a signal to the various inputs to change the speeds.
Is this possible, or am I going about this wrong?
  • Smart Operations
BJacqz
Commander BJacqz Commander
Commander
Posted: ‎2024-08-22 02:19 AM
Yes, it is possible.
Use RPS function (set to Yes, allowing ramp function commutatio) then affect to LIx.
It is possible to set Acc & ac2 with two different ramps, same for DEC and de2.
it is also possible to use preset speed if you want to assign a given speed to a LI (now we use DI as Digital input instead of Logic input this is what we use on new drives, ;-))
I hope it helps
Bruno Jacqz, Drives training leader
