Posted: 2024-06-12 02:38 AM
Hello, I have a task to implement 8 boilers cascade control based on operating hours with Schneider Modicon M172 PLC controller. And also for example if boilers 1-2-3-4 are on and heat demand drops, the first one which should turn off is Nr. 1 (because it was the first to turn on) and so on. I am programming with FBD language. Some information on how to start or even some kind of example would be greatly appreciated! Thank You in advance.
Posted: 2024-06-12 10:46 PM
You could use for this request the integrated Fan4StageMgmt block. This block is also available as 8 stage version (Library attached). The block can handle run time optimization for 8 devices. The block was designed for fans but in my opinion it should also work in your case
I would suggest to try the block in simulation mode. In the integrated TVDAs you could also better see how the block interact with other blocks.
Posted: 2024-06-17 10:15 PM
Hello, thank you for your help, i will try to implement this and i am going to let you know if that helped! 🙂
