Send InviteCancel
When you discover the host PDU, all the connected guest PDUs are also discovered.
Each guest PDU will have the IP address of the host PDU and will display as separate devices in the Gateway and in IT Expert.
Note: If the PDUs were previously discovered before they were configured for cascading, you must delete them, configure the hosts and all guest PDUs for cascading, and then rediscover the host PDUs.
