Split racks into compartments in the IT Advisor web client
ITA web client
Learn to use the EcoStruxure IT Advisor desktop client to build the data center infrastructure, add inventory, and import data to create a model.
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA web client
  • ITA web client
  • Split racks into compartments in the IT Advisor web client
  • Mark as Read
  • IT Advisor web client
  • Customizing web branding
  • Managing licenses
  • Working with SSL certificates
  • Managing your user account
  • Changing the language
  • Asset Visuals
  • Configure SAML 2.0 single sign on (SSO) in IT Advi...
  • Configure Azure for IT Advisor SAML SSO
  • Split racks into compartments in the IT Advisor we...
  • Managing licenses
  • Asset Visuals
EcoStruxure IT Support
Request Support
Back to ITA web client
  • Mark as Read
Sisko JLehr Sisko
‎2025-12-08 08:47 AM
on ‎2025-12-08 08:47 AM
Available in the IT Advisor web client only
You can divide racks into logical sections called compartments and add rack mountable assets to them. You can assign customers to compartments, especially beneficial for colocations.
Compartments are defined by new genomes. Before you can add compartments to a rack, you must assign the compartment genomes to your local genomes.
Add compartment genomes to your genome library
Go to Genomes  > Genome Library.
Search for Compartment. Select the genome(s) and then click Add to My Genomes.
Note: The default compartment sizes are 1U, 2U, and 4U. You can copy and edit them in the My Genomes view.
Add a compartment to a rack
  1. Select a room. In the Assets context, select a rack and expand the rack view.
  2. Click the lock icon to unlock the room and then click Add assets.
  3. Expand My Genomes and Compartment Cabinets and select a genome.
  4. Place the compartment genome in the rack.
You can then add rack mountable assets to the compartment.
Compartments support the following properties:
  • Name, serial number, and barcode
  • Custom properties
  • Tags
  • Labels
  • Colocation properties: Customer information, State, Contracted Power
