Managing ITA server settings
ITA server settings
Send InviteCancel
Note: Changing server settings no longer requires that you log in as root user (from ITA 8.0). You must now log in as the first OS admin user on the ITA server. This user is the administrator created during initial installation.
Accessing Webmin
The server management interface, Webmin, provides a web-based interface for server configuration. The latest version of Webmin available at the time of release is included with the IT Advisor installation/upgrade.
Open the Webmin web interface by selecting Administration > Webmin in the IT Advisor web client. Alternatively, type the address of your IT Advisor server in a Web browser folllowed by :10000, <https://>:10000 .
Log on to Webmin using the user credentials created during the IT Advisor installation.
Use the menu to the left to access server management features, such as
If you are experiencing issues accessing Webmin, check the privacy and advanced settings of your browser. If needed, contact your IT department for policies, etc. possibly preventing access.
Note: If you experience issues creating staging databases, a possible workaround is to upgrade your browser. For security reasons, it is recommended that you use the browser's settings such as deleting browser history on exit and that you don't use the browser options to remember credentials.
To do this, you must log on to the server with an SSH client, such as PuTTY (download here), and use the credentials of the first OS admin user on the IT Advisor server created during initial installation of the IT Advisor server.
