Server Power Consumption report
ITA: IT Optimize (on-premises only)
EcoStruxure IT Advisor: IT Optimize (on-premises deployments only) provides insight into the IT layer of the data center through integration with external IT systems.
Send InviteCancel
You can generate a Server Power Consumption report to identify the servers with the highest average power usage. Use this list to evaluate likely server candidates for upgrades, load sharing, or retirement.
The report is available fromAnalytics > Reportsif you have a valid IT Optimizelicense.
The ITA dashboard can be configured to show server power consumption data. The filter selections are:
