Configuring HPUX, Solaris, and AIX discovery
ITA: IT Optimize (on-premises only)
EcoStruxure IT Advisor: IT Optimize (on-premises deployments only) provides insight into the IT layer of the data center through integration with external IT systems.
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA desktop client
  • ITA: IT Optimize (on-premises only)
  • Configuring HPUX, Solaris, and AIX discovery
  • Mark as Read
  • Announcement: IT Optimize discontinued
  • Installing IT Optimize
  • Configuring IT Optimize server integration
  • Configuring IT asset discovery
  • Underutilized Servers report
  • Server Utilization report
  • Server Power Consumption report
EcoStruxure IT Support
Request Support
Back to ITA: IT Optimize (on-premises only)
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-10 07:42 AM
HP-UX, Solaris, and AIX discovery requires using a script. The current implementation of the SSH interface is not familiar with those operating systems out of box.
  1. On the IT Optimize server, open the IT Optimize installation folder.
    Default location: c:\program files\SchneiderElectric\ITOptimize.
  2. Open the bin/scripts sub-folder.
    In the folder, you see a set of scripts, one for each Unix type (see screenshot).
  3. Copy the viriditylisthw.HP-UX script to the /usr/local/bin folder on your target HP-UX client(s).
  4. Rename the script once it has been placed in the /usr/local/bin folder to viriditylisthw, removing the .HP-UX extension.
  5. Change permissions on the script to allow execution on the Unix host, i.e. chmod 755 viriditylisthw.
  6. Re-run the SSH discovery of the host(s).
    The SSH discovery interface will look for that script in /usr/local/bin and will execute it if found.
    Note: This script is ONLY used for discovery, not polling.
    The viriditylisthw script is a shell script and nothing is hidden.
  7. Run the script from the command line.
    You should see server information written to the screen in an xml-like format.
    The script looks for the HP-UX diagnostic utilities as well. If these tools are not present, some information might not be returned.
