VIJEO DESIGNER exchange data between HMIGTO and a client computer network
HVAC and Pumping Forum
Send InviteCancel
Posted: 2026-09-0405:46 AM. Last Modified: 2026-09-0405:47 AM
if you have a plc in your system, i recommend communicating with a plc because of your file request. PLC can produce communicating files. Anyway, if you would like to use vijeo as slave in this case you can configure your HMI program like at attached pictures (Computer is client and HMIGTO is a slave device)
