M172 modbus RTU function block
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • M172 modbus RTU function block
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
quang21
quang21
Explorer
Posted: ‎2024-09-24 01:39 AM
2023
Hello everyone, I want to ask if I use a function block to read the modbus and use the EN input to activate that Function block to read that register. In case I have 20 devices, but the response time is slow, do I need to hold that EN input long enough to read back or just trigger it once like pulse type is enough
  • HVAC
Bastian_Schmitz
Champion
Posted: ‎2024-09-24 01:52 AM
2
2020
You need to call the function in the background task. If this function need a long time to proceed, the whole background task need this time. Regarding to this point. A change of the en input is only possible in the next task, and that is when the FC is finished.
Replies 5
Bastian_Schmitz
Champion
2
2021
quang21
quang21
Explorer
Posted: ‎2024-09-24 02:52 AM
In response to Bastian_Schmitz
Thank you very much
quang21
quang21
Explorer
Posted: ‎2024-09-24 03:33 AM
Hi Bastian_Schmitz
Can i ask one more. how do i configure polling time for modbus using function block
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2024-09-25 12:34 AM
1966
in case of messages with a polling time, I would consider to manage them from Configuration perspective.
In terms of Polling time for messages defined in background, I would implement them using a TON which will trigger the message send and the TON reset
quang21
quang21
Explorer
Posted: ‎2024-09-26 08:19 PM
In response to FedericoM
Thanks You Verry Much
