USB extension TM171ADMI
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • USB extension TM171ADMI
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-09-21 05:29 AM
1620
My male-female extension cable for the TM171ADMI programmer got caught in a panel door and got broken. I am considering replacing it with a multi-port USB extender to enhance my laptop´s USB ports. Is it ok or it is better to keep it assigned to only one USB port ?
I should probably open another topic, but  I am lazy today: I assigned a paddle flow switch signal to a TON timer input. The compressor is allowed to start only after the TON timer elapses (when Tmer.Q = TRUE),
I had a cavitation or maybe air in the hydraulic system which caused the flow switch to generate a random pulsed input (going back and forth from 0 to 1) which means the compressor was never allowed to start. This is the expected behavior but there is no alarm associated with that, so I actually was able to detect that because I got connected to the PC.  Is there any easy way to detect something like this  before I star thinking about timers, flip-flops and other stuff ?
  • HVAC
  • ecostruxure
  • hvac
  • TM171
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-09-21 07:49 AM
1610
I've never tried, but I do not expect issues using a USB port extender.
About flow switch management you can try to use the FlowSwitchAlarm block available in the attached library:
Application_Addons.zip
Replies 4
FedericoM
FedericoM Mentor
Mentor
1611
otrotabi
otrotabi
Contributor
Posted: ‎2022-09-21 08:35 AM
In response to FedericoM
1597
Thank you.
There does not seem to be a FlowSwitchAlarm block available. You mean the configurable alarm block ? The LocalDigitalDebounce function would be able to filter this "noise" ?
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-09-21 08:45 AM
In response to otrotabi
1593
This is the block I'm referring:
LocalDigitalDebounce could act as filter for glitch, but the flowswitchalarm FB does more than that   
otrotabi
otrotabi
Contributor
Posted: ‎2022-09-21 09:06 AM
I see. This is a new release.
I had a previous one installed and it had less functions. Thanks.
