Posted: 2025-06-06 11:03 AM
I start a new topic but this is actually continuing this previous post (https://community.se.com/t5/HVAC-and-Pumping-Forum/Application-cycle-time-is-greater-than-2000-ms/td...) dealing with task time using PIDAdvance.
Following @FedericoM ´s advice, I decided to exclude all my programs from the current build, keeping only the one that actually shows me task time, and later adding programs one after the other until I found the guilty one. I also cleared HMI´s program.
Much to my surprise, task time is about 5 secs, so there´s something wrong here I think either regarding what information sysTskTmdMaxExeTime is giving or how to make use of it.
Just to make sure I was doing it properly, I started a new project from scratch and results are basically the same.
The pictures are from a running TM172PDG28R.
Posted: 2025-06-09 12:32 AM
the execution time of your project is: 4,7ms, unit measure of this variable is microsec
Posted: 2025-06-10 03:50 AM
Ok. That´s a relief.
Then I still need to find out why PIDAdvance complains about the 2000 msec task time. I will figure it out.
Regards
Posted: 2025-06-13 02:23 AM
It might happen during an application update
Posted: 2025-06-13 08:30 AM
Now that you mention it, it was usually the case and probably the best explanation. I was not using PIDAdvanced´s alarm and decided to include it as an alarm after that issue appeared.
Anyway I did move PIDAdvance FB to a program running as a background task in case that helps.
