Stationary Auto Tuning on ATV930 drives
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Stationary Auto Tuning on ATV930 drives
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Posted: ‎2022-09-13 08:44 PM
1
2418
Please explain how to do a Stationary or Non-Rotational Auto Tuning on ATV930 drive models - both through HMI and Somove application. Thanks.
BJacqz
BJacqz Mentor
Mentor
Posted: ‎2022-10-14 06:32 AM
The Autotunning mode has been changed this year on the latest versionning of ATV930. If the drive is equipped with a software compatible with ACVC, the autotuning can be bot rotational or static. Basically on latest drives the autotuning will be performed rotational.
Your question is how to start, in fact you go into motor parameters, and you will find motor tune (see p148 of the document joined).
Using SoMove, it will be possible too. when you connect your SoMove to your drive, you can enable the control panel ("device/control panel"), inside the control panel on bottom of your screen you can read Autotuning Apply/Erase. (see the picture linked).
Bruno Jacqz, Drives training leader
