Real time debugging on TM172 target
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Real time debugging on TM172 target
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-09 09:40 AM
1739
What happens if breakpoints are set on a real target (not on simulation)? Does the PLC freeze, stopping all control or it only allows us to use the debugger while timed and background tasks are still run?
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-11-10 12:58 AM
1725
both Timed and Background tasks are paused in case of breakpoint.
You can use trigger if you want to debug a variable on a specific point of the code without stopping it.
Replies 4
FedericoM
FedericoM Mentor
Mentor
1726
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-10 02:56 AM
In response to FedericoM
1717
Thanks. I am not familiar with triggers actually; I will take a look.  I want to check if a Boolean variable set at HMI which is almost inmediately reset at PLC after some action actually changes it´s state. Is a trigger the right way to check that?
Bastian_Schmitz
Champion
Posted: ‎2022-11-10 02:58 AM
In response to otrotabi
I would suggest for this use case is the oscilloscope the best tool
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-10 02:59 AM
Thanks.
