Multiple functions in Application_Addons Library (v1.3) are written for case insensitive environment
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Multiple functions in Application_Addons Library (v1.3) are written for case insensitive environment
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
obscuresc
obscuresc
Troubleshooter
Posted: ‎2020-09-16 07:38 PM . Last Modified: ‎2020-10-07 03:15 AM
5983
Hi all,
I'm using the latest version (v1.3) of the Application_Addons Library that is available in 'Toolbox SE M17x' via Box.
Some of the functions are written with lower case syntax and a majority also neglect using semi-colons on 'THEN's.
While the lack of semi-colons do not cause compile-time errors in my environment, the lower case syntax does.
I've been maintaining consistent case so far and have the case sensitive option enabled in 'Project options->Code generation'.
Could this library be updated with this in mind?
Cheers,
Jack
  • HVAC
Posted: ‎2020-10-07 02:37 AM . Last Modified: ‎2020-10-07 03:09 AM
Hi Jack,
thanks for your feedback. We will take this into account for the next release.
@FedericoM FYI
Best regards,
Pierpaolo
Replies 8
Rodrigo_Garcia
Rodrigo_Garcia Mentor
Mentor
Posted: ‎2020-09-24 02:39 AM
5950
Hello François, @Anonymous user : Could you please help?
Regards.
Rodrigo G.
Industrial Automation Community manager
Posted: ‎2020-09-24 02:43 AM
In response to Rodrigo_Garcia
@Anonymous user,: Hello Pierpaolo, can you ave a look at this request ? Thank you
Hi Jack,
@FedericoM FYI
Best regards,
Pierpaolo
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2020-10-09 03:37 AM . Last Modified: ‎2020-10-09 03:41 AM
5859
Hello Jack,
I've uploaded an updated version 1.3.1 on box.
Please let me know if it solved your issues.
Federico
@obscuresc @Anonymous user
obscuresc
obscuresc
Troubleshooter
Posted: ‎2020-10-11 03:24 PM
In response to FedericoM
Hi @FedericoM,
Didn't quite solve my issues; the functions in the BU2SI folder the ones I have issue with.
Cheers,
Jack
KCWong
KCWong Troubleshooter
Troubleshooter
Posted: ‎2020-10-14 09:06 PM
5801
Please send me the Box link. Thanks.
obscuresc
obscuresc
Troubleshooter
Posted: ‎2020-10-14 09:12 PM
In response to KCWong
5799
https://schneider-electric.app.box.com/s/3lc7iz6mjnfir5nj75l9kb6vbueqfkui/folder/50956872239
Jack
KCWong
Troubleshooter
Posted: ‎2020-10-14 09:14 PM
In response to obscuresc
Thanks a lot.
