Modicon TM171ODM22R
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Modicon TM171ODM22R
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
DylanPrescott.961
DylanPrescott.961
Explorer
Posted: ‎2023-08-07 07:10 AM
1008
Modicon TM171ODM22R
I have changed a Sontay sensor, To my knowledge Like for Like. and i'm almost sure almost that is that i've set the dip switches as a 0-10V sensor. However the sensor appears to be reading correctly in the room however back on the Graphics the readings are completely different. My question I suppose, is there anyway to check the configuration of the I/O on the Modicon TM171ODM22R controller?
I've never seen one of these before and want to know if you can connect to them or not as well?
Dylan Prescott
Bastian_Schmitz
Champion
Posted: ‎2023-09-25 10:52 PM
Please describ more detailed which type of sensor you want to connect. You could check the configuration of AI on TM17x via Ecostructure Machine Expert HVAC Commisioning Tab or via Bios Menu on the display
best regards
