Posted: 2025-01-17 12:49 AM
On all workstation with ME HVAC we have, after upgrade from version 1.6 to 1.7 will arise a problem with access to possibility setup of expansion modules configuration variables.
With all previous release ME when we open "SDO Set" page for M171E27 or "Advanced" for M171E14 / M172E12 when we use "Add' button a windows with list of config variables for a paricular module will apears as on attached picture "Expansion ver 1_6.png"
In ME HVAC 1.7 the same window is an empty list and there are no posiblity to add any configuration entries requested ( like on attached "Expansion Trouble ver 1_7.png".
We use Windows 10/11 polish
There is a way to add some configs manually ie type of analogue input for M171E27?
Posted: 2025-01-20 08:42 AM
Resolved. I've found in your file track to axis wiki and this is exacly point in entry:
JScriptReplacement"=dword:00000000
After that all works correctly
Posted: 2025-01-20 12:20 AM
Did you creat a new project? Till yet I could not reproduce the problem if I creat a new Project or if I open an old project.
Posted: 2025-01-20 01:27 AM
It seems to be a problem with population those listbox on Polish Windows 11. When I take this project and open it on workstation with english windows server 2016, I can add those entries to project and when I'll back to PC with Polish Windows I'll see entries added.
There was no this issue on 1.6 release. And when I rollback ME to 1.6 all works correctly, but in 1.7 is like on attached pictures
Posted: 2025-01-20 01:38 AM
Yes, I've create new one project and printscreens are just from there.
Posted: 2025-01-20 03:37 AM
I will try to investigate with R&D.
Posted: 2025-01-20 05:40 AM
please try to download, unzip and apply (double-click on it on Windows file explorer) the attached .reg file.
If it doesn't work you can restore the previous situation changing the key value to 1.
Let me know if this workaround will solve the issue
Posted: 2025-01-20 07:53 AM
When I try to open it by explorer or regedit the message appears in free translation: "You can't import ..... This particular file is not a script of the file register. It is possible to import only binary file registers from inside of Reg Editor"
Posted: 2025-01-20 08:10 AM
I'm not sure but seems to wiki/forum engine change and 'secures' this reg file in a first few rows downloaded file I can see something not reelevant to .reg :
</div>
<div class="mw-imagepage-upload-links"><p id="mw-imagepage-upload-disallowed">You cannot overwrite this file.</p></div><h2 id="filelinks">File usage</h2>
<div id='mw-imagepage-section-linkstoimage'>
<p>The following page uses this file:
</p><ul class="mw-imagepage-linkstoimage">
<li class="mw-imagepage-linkstoimage-ns0"><a href="/pwiki/index.php/JScript_Windows11" title="JScript Windows11">JScript Windows11</a></li>
</ul>
</div>
I'm affraid there is an effect any security policy on portal
Posted: 2025-09-29 01:28 AM
Hello, also experiencing issue where I cannot add "SDO SET" parameters of expansion module in 1.7 version. How can I fix it?
Posted: 2025-09-30 12:17 AM
have you already tried the fixes suggested above?
