MUX in FBD programs
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • MUX in FBD programs
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-07-20 08:37 AM . Last Modified: ‎2022-07-20 08:39 AM
2587
MUX in FBD programs
I have not used Mux until recently, but I am starting to do it. It can save lots of time when used properly ! For example, in the project for multiple displays uploaded by Federico yesterday:
ProbeDisplayed := MUX(currentview,probeAI1,probeAI2, probeAI3,probeAI4,probeAI5);
dp := MUX(currentview,1,1,2,0,1);
um := MUX(currentView,5,5,3,1,5);
	case currentview of
	0:
			ProbeDisplayed := probeAI1;
			dp := 1; (* 1 decimal point *)
			um := 5; (* °C *)
	1:
			ProbeDisplayed := probeAI2;
			um := 5; (* °C *)
	2:
			ProbeDisplayed := probeAI3;
			dp := 2; (* 2 decimal point *)
			um := 3; (* Bar *)
	3:
			ProbeDisplayed := probeAI4;
			dp := 0; (* No decimal point *)
			um := 1; (* %Rh *)
	4:
			ProbeDisplayed := probeAI5;
			um := 5; (* °C *)
	end_case;
However, in FBD I could not find a way to increase the number of inputs to the block. Is it possible somehow ? Default is 2 inputs.
  • HVAC
  • ecostruxure
  • hvac
  • TM171
  • TM172
Bastian_Schmitz
Champion
Posted: ‎2022-07-20 08:58 AM
2582
Click on the block and use increase pin from the toolbar
  • M172
  • TM171O
Bastian_Schmitz
Champion
2583
  • M172
  • TM171O
otrotabi
otrotabi
Contributor
Posted: ‎2022-07-20 09:16 AM
In response to Bastian_Schmitz
I see. I am so used to the right click procedure that works for other blocks that I did not notice that.  Thank you.
