M172 Display advanced simulation tools
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-06-0302:09 PM
Greetings!
Looking for a way to change remote parameters in simulation mode for M172 display. Yup, there are 3 controls for onboard probes (in my case I use flush model with none of them) but i could not find a rational solution to change remote parameters e.g. from different *.parx files.
Like workaround, I used to create a "plug" [actual definition not permitted in this community] code to simulate some vars but it takes a lot of time to reassign each var from target to "plug" and vice versa (including "plug" coding).
BTW it wold be nice feature to have opportunity to create virtual bridge between simulations of both M172 PLC and HMI to test whole rack offline.
