Link button on M172D to a M172P variable
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Link button on M172D to a M172P variable
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Yan_St-a
Yan_St-a
Explorer
Posted: ‎2023-06-03 09:36 AM
1458
Greetings!
Is there any quick way to link button/checkbox on M172D to a M172P variable or I miss something?
If I drag-n-drop Bool variable loaded from *.parx on a page I have only two available object types: edit and progress. And when I assign this variable to a button in properties I get compilation error A4097 (M172P => Object not found).
Or the only way to do so is to use Video_SetParam function?
  • HVAC
  • M172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2023-06-09 01:44 AM
the solution is through Video_SetParam, since version 1.5 you can also use PAR_ADR() operator:
FedericoM
FedericoM Mentor
Mentor
