Posted: 2024-10-09 04:32 AM . Last Modified: 2024-10-09 04:33 AM
I get this error while trying to add an EEPROM variable to a Menu
Cannot generate menu code (error message: Invalid Minimum value of parameter with IPA 47)
Since I could not figure out what was going on, I tried deleting it and creating a new variable. Now it generates basically the same error but it says:
Cannot generate menu code (error message: Invalid Minimum value of parameter with IPA8
Any idea what might be going on ?
Posted: 2024-10-10 11:38 PM
the error should be related to a minimum value not consinstent with the data type assigned to a Status variable or a EEprom parameter...you have probably deleted it.
Posted: 2024-10-10 03:55 AM
Although the message is quite cryptic it seems to be related to either too many variables on the menu or too many EEPROM variables being used. I solved after deleting some variables I do not need for this project.
