M171/172 Ethernet Port Supports
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-06-2008:27 PM
As mentioned at the catalog M171P or M172 embedded with Ethernet port which support both Modbus TCP and BACnet IP. Does these 2 protocols can simultaneously running on the same Ethernet port?
