Live debug mode with two M172 PLCs binding by using HVAC Installer
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • Live debug mode with two M172 PLCs binding by using HVAC Installer
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
neonguyen
neonguyen
Explorer
Posted: ‎2025-02-11 01:01 PM
1426
I am able to create binding between two M172 PLCs and download programs to them by using HVAC Installer.
I am trying to troubleshoot my program but the HVAC Installer software does not have live debug mode.
If I open project by using the normal EcoStruxure Machine Expert, the software does not allow me to use live debug mode and it show different code at the bottom right.
So, my question is how I can use live debug mode on PLCs that have binding?
Thank you.
  • HVAC
Bastian_Schmitz
Champion
Posted: ‎2025-02-11 10:17 PM
1424
You have in the installer also the possibility to put values on the watchlist or the oscilosp to monitor them. The problem with different code could be often solved via saving the project and connect again, or you need to make only a application download. This should not influence the binding configuration.
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2025-02-13 02:56 AM
If it is a Diff Code (sym), try to save the project.
If you are still in the development phase, simply download the source code from Programming (not Download All)
Replies 4
Bastian_Schmitz
Champion
1425
FedericoM
FedericoM Mentor
Mentor
StevenCho
StevenCho
Contributor
Posted: ‎2025-02-14 06:13 AM
What about trying 1.7.0 Version?
As I remember it said "Diff.code" issue is solved on the new version.
neonguyen
neonguyen
Explorer
Posted: ‎2025-02-14 11:16 AM
In response to Bastian_Schmitz
Thank you Bastian for the suggestion. I am able to use watchlist in the Installer software and it works fine.
