How to create typed enum?
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • How to create typed enum?
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
obscuresc
obscuresc
Troubleshooter
Posted: ‎2022-04-13 10:53 PM
5204
It seems that enumerations default to a DINT type.
I would like to change the type to a USINT so I can avoid casting every use of the enum.
I also don't want the type to be DINT across the project because I don't need the range of a DINT and it just makes program heavier to run.
The enum is per the following
State: (
	Idle := 0,
	Pending := 2,
	Active := 3,
	Fault := 4
I've tried casting in the following manners;
State: (
	Idle := TO_USINT(0),
	Pending := TO_USINT(2),
	Active := TO_USINT(3),
	Fault := TO_USINT(4)
State: (
	Idle := 0,
	Pending := 2,
	Active := 3,
	Fault := 4
) USINT;
Thanks.
  • HVAC
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-04-13 11:12 PM
5197
unfortunately there is not a way to specify the type of an Enumeration, which is assumed by the compiler as a DINT.
You should write:
usiVar := TO_USINT(State #Idle);
If you want to force a different type, I suggest to use CONSTANT variable, in this case you can specify the type.
If you want to define the type of an explicit value in your code, you can write USINT#5 and keep TO_USINT() for casting of variables, expressions.
Federico
Replies 5
FedericoM
FedericoM Mentor
Mentor
5198
You should write:
Federico
obscuresc
obscuresc
Troubleshooter
Posted: ‎2022-04-13 11:26 PM
In response to FedericoM
5190
I was hoping to avoid having to cast each use of the enum.
Constant variables have lots of overhead because they have to be defined as VAR_EXTERNAL anyway.
DINT will have to suffice.
Thanks @FedericoM
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-04-13 11:38 PM
In response to obscuresc
Global constants can be used inside functions and fbs without the need of additional declaration inside the block
Federico
dFx
dFx
Explorer
Posted: ‎2022-04-20 11:39 PM
5077
As far as I know, with codesys you can : CODESYS Online Help
TYPE COLOR : ( white := 16#FFFFFF00, yellow := 16#FFFFFF00, green := 16#FF00FF00, blue := 16#FF0000FF, black := 16#88000000 ) DWORD := black; // Basic data type is DWORD, default initialization for all COLOR variables is black END_TYPE
Extensions to the IEC 61131-3 standard
The basic data type for an enumeration declaration is INT by default. However, you can also declare enumerations that are based explicitly on another integer data type.
basic data type : INT | UINT | SINT | USINT | DINT | UDINT | LINT | ULINT | BYTE | WORD | DWORD | LWORD
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-04-21 12:21 AM
In response to dFx
the question was related to the software Ecostruxure Machine Expert HVAC, which is not Codesys based.
Federico
