How to change floating point data type to ASCII in EcoStruxure Machine Expert - Basic software?
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • How to change floating point data type to ASCII in EcoStruxure Machine Expert - Basic software?
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Logic Controller - Modicon M221
beryllarachman00
beryllarachman00
Explorer
Posted: ‎2022-02-11 06:24 PM
2
4462
Hello guys, so I'm working on a project at my company where I was asked to make sensor readings printable with a serial printer. Here I am a little confused with the floating point data type if I change it to ASCII the value becomes random. Is there a solution to this problem? I thank you in advance. (sorry for my bad English)
  • EcoStruxure Automation Expert
  • float to ASCII
BevanWeiss
BevanWeiss
Champion
Posted: ‎2022-02-14 01:36 PM
If your float value is -0.01 and you convert this to ASCII then I would expect it to result in the following byte/character array values:
0x2D, 0x30, 0x2E, 0x30, 0x31
Depending on how the ASCII is stored, there may be a prepended length (0x05), maybe even 0x00,0x05 or 0x00,0x00,0x00,0x05 depending on the size of the length field (8bit, 16bit, 32bit).
It may also be terminated with a null character 0x00
I'm not familiar with the FLOAT_TO_ASCII function however, so you should refer to the manual for this function to determine in what format it will produce its output.
Shanoes
Shanoes Troubleshooter
Troubleshooter
Posted: ‎2022-02-17 02:35 AM
Hello @beryllarachman00
This forum is for  EcoStruxure Automation Expert and IEC61149 related topics, so unfortunately your question is in the wrong place!
I will move your post to a more appropriate forum...
Shane Ayerst
