HMI Automatic documentation
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • HMI Automatic documentation
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-21 06:00 AM
1437
What is the criterion used by the automatic documentation script to generate the HTML documentation list. It does not follow either the pages tree or an alphabetical order as far as I could see.
It would be nice if one could define a logical order according to how the user interface is supposed to work.
Also, the programming manual says that Documentation.xsl file can be personalized to redefine the report stye. Are there any examples available?
  • HVAC
  • Ecostruxure HVAC
  • TM172
FedericoM
FedericoM Mentor
Mentor
Posted: ‎2022-11-22 01:35 AM
1420
unfortunately there are no examples, documentation is created with a xsl document which extract data from the xml file representing the HMI project.
If you add to the documentation.xsl file present in your project the line in bold, pages will be sorted in alphabetical order:
<xsl:for-each select="PRJ_RESOURCES/PAGES/PAGE">
<xsl:sort select="@name"/>
<table class="table1">
<tr class="titlePage">
FedericoM
FedericoM Mentor
Mentor
1421
otrotabi
otrotabi
Contributor
Posted: ‎2022-11-22 07:33 AM
In response to FedericoM
Thanks. That´s a start.
I´ve never done much with XML files. To start with, naming the pages in alphabetical order does give me a better order in terms of the documentation. I need to figure out how to modify the xls file so that page title gets stripped of maybe the first two characters, but I guess I will figure it out.
If you already know the answer it would help.
Regards
