EcoStruxure Machine Expert HVAC - How to use "Disable IF NOT DEF"
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • EcoStruxure Machine Expert HVAC - How to use "Disable IF NOT DEF"
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
EcoStruxure™ Machine Expert - HVAC
neonguyen
neonguyen
Explorer
Posted: ‎2025-09-11 12:37 PM
994
I have a question regarding EcoStruxure Machine Expert HVAC software.
When I right-click on a network and open Network properties window, there is section called "Disable IF NOT DEF".
I am wondering how to use this feature in the software.
Thank you.
  • HVAC
M_Cervati
Troubleshooter
Posted: ‎2025-09-12 01:56 AM
In the field "Disable IF NOT DEF" you can specify the name of a variable defined like global variable the network is included in the compilation. If the variable is not defined the network is skipped and the code is not compiled and so executed. Take a look to the help on line
Best regards
Marco Cervati
Replies 4
M_Cervati
Troubleshooter
Best regards
Marco Cervati
Bastian_Schmitz
Champion
Posted: ‎2025-09-15 02:44 AM
To better understand the usecase, I could not only use a self made global variable , I could also a target variable which is related to a related target?
M_Cervati
Troubleshooter
Posted: ‎2025-09-15 07:01 AM
1
940
Yes, it is possible to have a "related" target variable like for example cfg_AI12, in case of TM172P 18 IO the code under IFDEF is not compiled.
Marco
neonguyen
neonguyen
Explorer
Posted: ‎2025-09-16 08:11 AM
In response to M_Cervati
Thank you for your answer.
Now, I understand how this works.
