Posted: โ2023-12-22 06:15 PM
Is there any way to a load program file from M172?
Even when I connect to PLC with latest program file which is same as PLC, Sometimes It display [diff.code] Status.
So I can't sure which program is latest or not.
If the feature is not supported, How do you guys managing the program files?
Posted: โ2024-01-03 11:53 PM
check the attached example project for M172.
It shows the project version you can define here:
In the example it is shown on the main view of the display and also copied on a couple of status vars.
Project version can be read also from Installer Network scan:
Posted: โ2024-01-01 11:46 PM
source code is not downloaded on the PLC, so it can't be uploaded.
I know the source check is not perfectly working.
If you change connection settings, you'll have a diff. code, in this case it is enough to save the project.
My suggestion is to change the project version at any released source change.
Posted: โ2024-01-03 02:39 AM
I am glad Steven asked this question, it has always been a problem for me as well.
Federico, what exactly are you suggesting ? Having an EEPROM variable named "ReleasedVersion" which is updated every time you download a new program to the PLC ? If that is how you manage that, how would you automate it ? Is it possible to run a task either at boot or init that runs exactly once, meaning after a new program is downloaded ?
Posted: โ2024-01-04 02:53 AM
I understand now. Thanks!
Is there any documentation regarding the PLC database structure ? What other data are available ?
Posted: โ2024-01-11 04:35 AM
Thank you for the answer.
It could be suggested to our customers as a temporary alternative.
But is there any future plan for UPLOAD FEATURE?
Thank you๐
Posted: โ2024-01-11 11:23 PM
These PLCs are designed mainly for OEM, most of them don't want this feature to protect their know how.
Posted: โ2024-01-14 06:47 PM
Thank you for the reply.
To protect the KNOW-HOW, we can use the protection feature like a password.๐
You said "most of them", but "most of them" in Korea are wondering why it is not supported. And really want..
Youโve reached the end of your document
