Connection 2 PLC and 2 HMI in different locations
HVAC and Pumping Forum
Send InviteCancel
Posted: 2023-05-1901:13 AM
Hi
I need advice on how to do a connection like that :
The PLC is TM251MESE, HMI's is XBTGT4330 and XBTGT7340 The buildings are about 200 meters apart, the biggest problem is how to add IP addresses from different network in HMI's. I thinking about using IP Routing on TM521 but I don,t exactly how does work. If there was a possibility add addresses from the same network in ETH1 and ETH2 thats solved the problem, but the addresses must be different.
