ATV320 EDM using DQ output
HVAC and Pumping Forum
Select a Country
  • Industrial Automation
  • HVAC and Pumping Forum
  • ATV320 EDM using DQ output
FedericoM
FedericoM Mentor
119
Bastian_Schmitz
Bastian_Schmitz Champion
64
M_Cervati
M_Cervati Troubleshooter
18
Jimbo
Jimbo
Explorer
Posted: ‎2024-10-24 03:16 AM
2449
I want to set up the STO function on the ATV320 inverter. I need to use the External device monitoring to achieve Cat4 safety requirement. There doesn't seem to be a dedicated EDM output, can the DQ+, DQ- be used as EDM feedback?
  • Safety
Possebom
Possebom Contributor
Contributor
Posted: ‎2024-10-25 04:58 AM
1
2418
We can configure the output DQ as feedback from the STO. A screenshot of SoMove and the Safety functions manual, which contains wiring diagrams according to Safety CAT, are attached
Possebom
Contributor
1
2419
Jimbo
Jimbo
Explorer
Posted: ‎2024-10-28 02:16 AM
In response to Possebom
Hi, thanks for the feedback it was very helpful. I didn't initally see the feedback options for the DQ assignement. I see the "power removal state" is the correct selection.
