Posted: 2014-07-24 07:57 PM
Hello Everyone
First i sorry, i'm not english well.
but i needs your help com'x200 Road map.
i will be plan new bussiness using com'x200. becoz i needs com'x200 function, example
"arithmatic operation" and "TOU Module"
(i knows it is support EOO Server or higher cloude service support possible)
A. system configration.
From main utility meter send pulse(wh and EOI) to the com'x200.(not EOO or Server Cloud service)
B. i Needs Function com'x200 ,
arithmatic operation and TOU.
When will be support possible it?
The Com'X 510 will be launched in Q1 (January) 2015. At a high level, this will combine the on-board data logging and visualization (dashboards) of an EGX300 with the hardware, communications, and features of a Com'X 200. We do not have TOU or calcs in this first release.
Hi SK!
No worry about your English! 🙂
Can you provide details on what exactly are you trying to achieve by doing this? What is your end goal? Remember that you cannot use the Com'X200 to do Energy Management on its own. They are no graphics, no calculations, etc.... all you can do is read the current value and push your values somewhere (EO, EOO or third party).
The Com'X500 that should be released in 2015 will have the ability to create basic graphics and show trend logs. I don't have the exact spec so not sure whether it will support TOUs or calcs.
If you need a standalone small onsite energy management solution with pulse and you don't need the GPRS, you could use the SmartStruxure Lite box (Can2Go) which also can take pulse, however, we should test whether it will accept the pulse from the KEPCO meter. If you want I will bring one next time I come to South-Korea, and we can try it out.
I'll try to write an article when I'm back from vacation on how to do it and you could also try on your own.
Posted: 2014-08-07 08:23 AM
Thank you Mr. Coene
i See it.
