Upgrade PAS800L firmware to V9
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Upgrade PAS800L firmware to V9
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
58
Randi_Dolan
46
Olivier_GARAULT
Lieutenant JG Olivier_GARAULT Lieutenant JG
Lieutenant JG
Posted: ‎2024-06-17 07:26 AM . Last Modified: ‎2024-06-17 07:28 AM
1134
Bonjour,
j'ai besoin de mettre à jour un PAS800L de V6 à V9 et j'ai un message d'erreur.
Que je passe par les pages Web embarquées ou par EPC, c'est la même chose.
Quelqu'un a déjà eut ce message?
"Update package signature verification failed"
"Signature invalide du groupement"
I need to update a PAS800L from V6 0 to V9 and I have an error message.
Whether I go through the embedded web pages or through EPC, it's the same thing.
Has anyone received this message before?
  • Legacy Gateways & Energy Servers
Tags (2)
  • PAS800
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2024-06-17 08:40 PM
Hello @Olivier_GARAULT
Can you please have a check on the PAS date and time settings. If it is not correct, please set the current date & time of your system and then proceed for update.
In this case i would suggest you to update the firmware by connecting one to one through webpage (direct, PAS to your laptop). If you still face the issue, please raise a support ticket with PAS logs.
Regards
Udhayakumar A K
ESXP System Support Expert
UdhayakumarAK
Commander
Regards
Udhayakumar A K
Guillaume_Evrard
Captain
Posted: ‎2024-06-17 09:21 PM
Hello @Olivier_GARAULT ,
This is hapening when there is an issue with the bundle you try to install . As you tried using EPC and EWP this should not be the case. Have you tried to set date and time as highlighted by Udhayakumar ? Have you tried to install 1.8 just to try  ?
Olivier_GARAULT
Lieutenant JG
Posted: ‎2024-06-18 12:27 AM
Thank's guys for your answers.
It's was the date. (1970)
Now the PAS800 is at the good date and good Firmware.
