Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Send StruxureWare Lite aka Can2Go data to Energy Operation
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Send StruxureWare Lite aka Can2Go data to Energy Operation
Romain_Polette
Kirk Romain_Polette Kirk
Guillaume_Evrard
53
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
LaurentCoene
Captain LaurentCoene Captain
Captain
Posted: ‎2014-10-20 07:01 PM
Even though, we do have the great article from , many people have been asking for this old post from the defunct energyoperation.info blog. So there it is:
In our second topic about the StruxureWare Lite offer, we’ll show you how, thanks to the Lua scripting languague, you can create native EO file format (or any file format) and send them to Energy Operation.
First you need to identify the data you want to send and create the metes in Energy Operation. Again, since it’s all scripted in Lua, you could use whatever you want, but in our case, I decided to use the Name of the objects. You can see that in your explorer window:
5002
For the temperature sensors, just select the sensor in the tree, and it will also appear in the grid.
5003
Log in to Energy Operation, and create your metering tags where you want to see the data:
5004
Now Energy Operation is ready to receive the data.
Next, we need to create the actual csv file in the StruxureWare Lite box. To do that, we need to create a Lua script.
In the explorer view, click on Add Objects (the little + green icon):
5005
Then in the filter, select “Lua Program”. Select of of the available program which will then appear as selected in the right list, and click on Add Objects.
5006
Now your script will appear in the Explorer windows for your SmartStruxure Controller.
Select the newly created script, and rename it to whatever makes sense to you. In our case, it’s “Create EO File Lua Program”.
5007
Here is the code you need to put:
if createEOFileInit == nil then -- Initialization
createEOFileInit = true
  -- Interval Length in minutes
intervalLenght = 5
  -- Initialize list of devices.topics (tags) to be trended
  -- The Object Name is the Unique ID in Energy Operation and should be unique to the implementation.
tags = {"AI44", "AV3"}
-- File name
  fileName = scl.getserial() .. "_" .. scl.getmac():gsub(":", "") .. "_" .. ME.CFG1_Node_Instance.value .. ".csv"
  -- File Header
  header = "## ACTION:UPDATE ENTITY:MeterData SCHEMA:Default VERSION:1.0.0".."\r\n" .. "AcquisitionDateTime,Value,MeterLocalId\r\n"
else
-- This section will read points at every interval and write to the CSV file
timer = os.date("*t")
if timer.min % intervalLenght == 0 and flag == 0 then -- Run at every intervals
  buffer = ""
for tagIndex = 1, #tags do -- Generate string with all arguments to be written to CSV
timestamp = string.sub(os.date(),0,10) .. "T" .. string.sub(os.date(),12,19) .. ".0000000+00:00,"
arglist = scl.nodes["ME"][tags[tagIndex] .. "_Present_Value"].value .. "," .. scl.nodes["ME"][tags[tagIndex] .. "_Object_Name"].value
buffer = buffer .. timestamp .. arglist .. "\r\n"
  end
file, info = io.open(fileName, "a+") -- write to CSV
if file then
  size = file:seek("end")
  if (size == 0) then
  -- file is empty. Ensure to add the header
  file:write(header)
  end
file:write(buffer)
file:close()
end
arglist = ""
flag = 1 -- Action completed once, no need to run more until the next interval
end
if timer.min % intervalLenght ~= 0 then
  flag = 0
end
end
As specified in the header, there are two parameters that you need to modify. The interval lenght (in minutes) which you should try to match to your utility. In addition, the list of objects that you want to export.
Once you run it, after the first interval is passed, you will start to see a file in the upload manager of your controller.
5008
Now we only have to send the file. To do so, we will create another Lua script. Here is the code for it:
if sendToEOInit == nil then -- Initialization
sendToEOInit = true
-- Send filename to EO ftp server
function ftpFile()
now = os.date("*t")
ftpResult, ftpError = ftp.put{
host = "10.0.0.5",
user = "yourUsername",
password = "password",
argument = "can2go_" .. now.hour .. now.min .. "_" .. fileName,
source = ltn12.source.file(io.open(fileName, "r"))
end
-- Is it time to try to send again?
function isItTime()
this_time = scl.sysclock()
if (this_time - last_time >= frequency) then
last_time = this_time
return true;
else
return false;
end
end
-- debug function
function writeToDebug(str)
print(os.date() .. ": " .. str)
end
-- Initialize a few more variables
frequency = 0 -- First run happens now. Subsequent run happens depending on result of FTP (every minutes or hourly)
  last_time = scl.sysclock()
else
  if (isItTime()) then
  writeToDebug("Initiating FTP transfer.")
ftpFile()
  if ftpResult >= 1 then -- success
  writeToDebug(fileName .. " File succesfully sent.")
  if (io.open("previous_" .. fileName) ~= nil) then
  os.remove("previous_" .. fileName)
  end
  os.rename(fileName, "previous_" .. fileName) -- Create a new backup with current file
  frequency = 3600
  elseif ftp_err ~= nil then -- error
  print("ftp put error : " .. ftp_err)
  frequency = 60
  end
end
end
The script will by default send data every hour, but you can change this, by changing the frequency at the end of the script from 3600seconds to whatever you would like. Be sensible about it though!
Finally, make sure to change the host, username and password to send the data to the right implementation.
That’s it! What thing we need to highlight though. The box currently does not support SSL encryption. You are sending data over FTP which means the data is not encrypted. After talking to the team, they seem to have a plan to add support for HTTPS, so more good things to come.
Create EO File - LC.lua.zip
FTP to EO - LC.lua.zip
Tags (6)
  • can2go
  • energy
  • eo
  • ftp
  • mpm
  • operation
Replies 0
