SNMP via EGX300
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • SNMP via EGX300
Romain_Polette
Kirk Romain_Polette Kirk
113
Guillaume_Evrard
55
Randi_Dolan
46
Thierry_Baudard
Commander Thierry_Baudard Commander
32
Grant_IPACS
Commander Grant_IPACS
Commander
Posted: ‎2019-01-01 09:40 PM
1157
SNMP via EGX300
Hi All,
We have a client withan existing setup of various NS/NSX/PMxxx etc connected to an EGX300.
They have a new IT manager who has asked if we can modify the setup to provide the data to their real time system via SNMP.
My understanding is the EGX only supports SNMP ofr the status of the EGX300 only... not the downstream gear.
My experience with SNMP is not extensive, but i think the EGX is a MODBUS serial to ethernet gateway only... not serial to SNMP.
Am i right?
Are there any other products available for the purpose?
Regards
Grant
Regards
Grant
GENJUA
Lt. Commander GENJUA
Lt. Commander
Posted: ‎2019-01-01 09:51 PM
Yes you are right.
BR
Genjua
greg_expoenergy
Lt. Commander greg_expoenergy
Lt. Commander
Posted: ‎2019-08-19 09:45 AM
1138
I know it is very much after the fact but refer to this
http://www.adfweb.com/home/products/SNMP_Modbus.asp?frompg=nav20_7&loc_phy=1028916&k001=p&en-k1=snmp...
GENJUA
Lt. Commander
Posted: ‎2019-08-21 12:07 AM
The link you are referring contain ADFWEB gateways/converters from Modbus Master, Modbus Slave to SNMP.
If you go for this solution you have to replace EGX300 with ADFWEB Gateway and connect modbus salves to it.
I never used ADFWEB gateway for SNMP Conversion so you are advised to contact technical support before buying it.
Another solution using Babel Buster SPX by using this you can fetch data from EGX300 over Modbus TCP and Convert it to SNMP. A single gateway supports up to 300 SNMP Points. I used it several times on a different project and the result is awesome.
BR
Genjua
