Panel Server PAS600 replacement for COMX210
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Panel Server PAS600 replacement for COMX210
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
ArmandV
Lieutenant | EcoXpert Master ArmandV Lieutenant | EcoXpert Master
Posted: ‎2023-01-10 04:37 AM
1949
Hi all,
The Panel Server PAS600 is recommended as a direct replacement of the COMX210 device.
It however looks like the panel servers are lacking valuable features of the COMX210 devices, such as the digital and analogue inputs.
Is there any other substitution device compatible with Power Monitoring Expert, which is also more comparable to the specs of the COMX210?
Armand
  • Product selection
Romain_Polette
Kirk
Posted: ‎2023-01-10 04:40 AM
3
1941
Hello @ArmandV ,
If you only need 2x DI => then use PAS600L commercial reference.
If you need more DI for pulse counting or breaker monitoring => then better use a Smartlink A9XMSB11.
Then all your Smartlink IO Channels will be compatible with PME. You will need to create Logical Device in Management Console.
Romain POLETTE
Solution Architect - France Operations
Replies 4
Romain_Polette
Kirk
3
1942
Hello @ArmandV ,
Romain POLETTE
ArmandV
Posted: ‎2023-01-10 05:14 AM . Last Modified: ‎2023-01-10 05:15 AM
1932
Hi @Romain_Polette ,
Thank you for the feedback and advice.
Armand
Romain_Polette
Kirk
Posted: ‎2023-01-10 06:00 AM
1
1926
Hi @ArmandV ,
I forgot something important.
If you choose to use the 2x Digital Input embedded in a PAS600L, you will need to create a PME custom driver based on the Panel Server internal Modbus map. Because DI status / counting data are stored in the Panel Server. For the moment, no Panel Server driver is available for PME.
If you choose the Smartlink Modbus, then it will be native to PME because the driver is native for many years.
Romain POLETTE
ArmandV
Posted: ‎2023-01-10 06:04 AM
Thank you very much for the additional information on the PAS600L @Romain_Polette , that is good to know.
