| User | Count |
| 116 | |
| 57 | |
| 46 | |
| 32 |
Hello Gateway and Energy servers community,
For your info, the new Panel Server firmware 002.003.000 is currently available on se.com web site as well as user guide, release notes (for what's new), modbus file, instruction sheet, catalogue, cybersecurity guide ....
Detailed informations are available here
To upgrade, you can retrieve this firmware on Panel Server web page (if your current PaS firmware is not too old):
OR on se.com (take care to choose the correct firmware according the hardware revision of you PaS and the model you have: PAS400, PAS600, PAS800...)
OR with next EPC application > or = v2.37.0
Enjoy the new release!!
Regards
Dear Eric,
we are facing some issue on firmware update on PAS600.
We have several PAS600 with FW 002.002.001 and we are not able to upgrade to 002.003.000 since the the procedure says "Not compatible firmware"
Hello @GabrieleP ,
Your hardware version is 2.0 and your are trying to upgrade with a HW v1.0 Firmware.
Please download the following file and upgrade your PAS600:
Refer to the following section of the user guide regarding HW version of PAS600 / PAS800:
Thanks, you are right. We had received 48xPAS600 and some HW001 and some HW002.
Regards
hello @GabrieleP ,
If you select download the FW from EWP, you will get the right one automatically as explained by @Eric_HAVAS
Kind Regards
