PaS600 vs PaS800 vs PaS400
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PaS600 vs PaS800 vs PaS400
Romain_Polette
Kirk Romain_Polette Kirk
116
Guillaume_Evrard
58
Randi_Dolan
46
RogelioHdezD
Ensign RogelioHdezD Ensign
Ensign
Posted: ‎2022-07-18 04:28 PM
5404
Is there any table to compare at least PaS600 and PaS800 features? Both are valid for Edge connection, right?
Better if the table has the features of the three models.
Thanks & BR
Rogelio Hdez
TL GAC
  • Product selection
Replies 5
Randi_Dolan
Commander
Posted: ‎2022-07-18 04:35 PM
5396
Hi Rogelio,
This document, PowerLogic Energy & Power Meters Catalogue for Panel Builders, has the descriptions and data sheets for the Panel Servers starting on page 127.   You can use these for comparison.
Randi
RogelioHdezD
Ensign
Posted: ‎2022-07-18 05:00 PM . Last Modified: ‎2022-07-18 05:01 PM
5392
Hi Randy,
Thanks for your answer. I am in doubt now, because in the last Open Line, PaS600 was indicated like the only one suitable for connection to the cloud (EAA). For Edge, either of them is valid.
Is this because of firmware versions available today?
Rogelio Hdez
TL GAC
Guillaume_Evrard
Captain
Posted: ‎2022-07-18 10:26 PM
As of today the cloud ETP connector is only available on PAS600, but PAS800 will get it soon. so PAS600&800 will be suitable for Edge and cloud. For EAA we recommend to wait as 1.3.2 is not working well.
Guillaume
SwapnilP
Ensign SwapnilP
Ensign
Posted: ‎2024-04-25 11:33 PM . Last Modified: ‎2024-04-25 11:35 PM
1
2802
Model PAS800/L PAS600/L PAS400
Product name Panel Server Advanced Panel Server Universal Panel Server Entry
Description EcoStruxure Panel Server - advanced datalogger, energy server, EcoStruxure Panel Server - universal wireless, concentrator modbus gateway  EcoStruxure Panel Server - entry wireless, concentrator
Price
Device Application Gateway
Energy server
Data logger
Gateway Gateway
[Us] rated supply voltage 110...277 V AC/DC 50/60 Hz
or 24 VDC
or 24 VDC
communication gateway Ethernet TCP/IP to wireless devices Ethernet/serial Ethernet TCP/IP to wireless devices Ethernet/serial Ethernet TCP/IP to wireless devices
Communication network type Ethernet, 10/100BASE-T
Wi-Fi 2.4 GHz
Wi-Fi 5 GHz
Wireless, IEEE 802.15.4
Modbus RTU, Modbus RTU client even/odd or none 1.2...115.2 kbit/s
Wi-Fi 2.4 GHz
Wi-Fi2.4 GHz
Wi-Fi, IEEE 802.15.45 GHz
Communication port protocol Modbus TCP
DHCP
HTTPS
NTP/SNTP
IPv4
IPv6
TCP/IP
Modbus TCP
DHCP
HTTPS
NTP/SNTP
IPv4
IPv6
TCP/IP
Modbus TCP
DHCP
HTTPS
NTP/SNTP
IPv4
IPv6
TCP/IP
Communication port support 2 RJ45 ETHERNET
Screw terminal block RS485
2 RJ45 ETHERNET
1 RJ45: ETHERNET
Number of server 32 slave(s)Modbus RTU - without repeater
128 slave(s)Modbus RTU - with repeater
128 slave(s)Modbus TCP
40 slave(s)IEEE 802.15.4
20 slave(s)IEEE 802.15.4
Communication Service Device Profile for Web Services (DPWS)
Modbus TCP client
Modbus TCP server
SNTP client
DHCP client
DHCP server
Web server (energy & operation efficiency)
Modbus TCP client
Modbus TCP server
SNTP client
DHCP client
DHCP server
Modbus TCP server
SNTP client
DHCP client
Number of clients 64 Modbus TCP server 64 Modbus TCP server 64 Modbus TCP server
Memory capacity 32 GB eMMC
512 MB NAND
512 MB NAND 512 MB NAND
data recording Historical dashbaording and trending
3 years data logs
NA NA
Function Available Embedded web page for configuration and upgrade
Diagnosis capabilities
Diagnostic report
Diagnostics on communication
Embedded data logger
Event Logger
Energy management
With integrated web server
Firmware update
Configurable event
Backup/restore configuration
CSV export
Diagnostic report
Energy management
Firmware update
Configurable event
Event Logger
Diagnostic report
Energy management
Firmware update
Configurable event
Event Logger
Topology Separated Ethernet network
Switched Ethernet network
NA
Web services HTTPS server HTTPS server HTTPS server
Range compatibility EcoStruxure Facility Expert
EcoStruxure Power Operation
EcoStruxure Power Monitoring Expert
EcoStruxure Asset Advisor
EcoStruxure Energy Hub
EcoStruxure Resource Advisor
Mounting Support DIN rail DIN rail DIN rail
Depth 2.76 in (70.2 mm) 2.76 in (70.2 mm) 2.76 in (70.2 mm)
Height 3.66 in (93 mm) 3.66 in (93 mm) 3.66 in (93 mm)
Width 2.83 in (72 mm) 2.83 in (72 mm) 54 mm
Country of origin SG IN
Product Certifications CE
cULus
CB
RCM
UKCA
FCC
IC
DNV Marine
ANSI RF
CE
cULus
CB
RCM
UKCA
FCC
IC
DNV Marine
ANSI RF
IACS E10
CE
cULus
CB
RCM
UKCA
FCC
IC
DNV Marine
ANSI RF
IACS E10
Standards IEC 61010
IEC 61010-1
IEC 61010-2-201
UL 61010
UL 61010-1
UL 61010-2-201
EN 61010-1
EN 61010-2-201
CAN/CSA C22.2 No. 61010-1-12
CAN/CSA C22.2 No. 61010-2-201
IEC 62974-1
IEC 62443-4-1
IEC 61326-1
EN 61326-1
ETSI EN 301 489-1
ETSI EN 301 489-17
EN 55032
EN 301-893
CISPR 11
ETSI EN 300 328
IEEE 802.15.4
IEEE 802.11a/b/g/n
IEEE 802.3 af/at
FCC CFR 47 part 15 class A
EN 62311
IEC 62311
IEC 61010
IEC 61010-1
IEC 61010-2-201
UL 61010
UL 61010-1
UL 61010-2-201
EN 61010-1
EN 61010-2-201
IEC 62974-1
IEC 62443-4-1
IEC 61326-1
EN 61326-1
ETSI EN 301 489-1
ETSI EN 301 489-17
EN 55032
CISPR 11
ETSI EN 300 328
IEEE 802.15.4
IEEE 802.11a/b/g/n
IEEE 802.3 af/at
EN 62311
IEC 62311
ANSI C63.10
IEC 61010
IEC 61010-1
IEC 61010-2-201
UL 61010
UL 61010-1
UL 61010-2-201
EN 61010-1
EN 61010-2-201
IEC 62974-1
IEC 62443-4-1
IEC 61326-1
EN 61326-1
ETSI EN 301 489-1
ETSI EN 301 489-17
EN 301-893
EN 55032
CISPR 11
ETSI EN 300 328
IEEE 802.15.4
IEEE 802.11a/b/g/n
IEEE 802.3 af/at
EN 62311
IEC 62311
ANSI C63.10
Guillaume_Evrard
Captain
Posted: ‎2024-04-29 09:33 PM
Not sure if the table is up to date...
Kind Regards
