PAS800L with PM5320
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PAS800L with PM5320
Romain_Polette
Kirk Romain_Polette Kirk
117
Guillaume_Evrard
59
Randi_Dolan
46
innoglass
innoglass
Cadet
Posted: ‎2024-02-04 08:24 PM
809
PAS800L with PM5320
I'm new to schneider electronic device.  Currently I have Ecostruxure Panel server PAS800L which connect to the switch.  And PM5320 power meter also connect to the switch.  I use the Schneider Power Commission app to discover both device.  But How I can let the reading from PM5320 can show on the graph in the panel server?  What configuration I should set in the power commission app to let both device communicate?
  • Commissioning
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2024-02-20 11:53 PM . Last Modified: ‎2024-02-21 01:52 AM
Hello @innoglass
To view the device data in panel server webpage, you need to discover/add the device in Panel Server. Please follow the steps mentioned in the user guide , https://www.productinfo.schneider-electric.com/ecostruxurepanelserverguide/doca0172-ecostruxure-pane...
To view Trends of the device data, follow the below steps
1. After adding the device.
2. You have to enable "Data Sampling" in Settings->Data Management. For each device you can configure the parameter to be logged.
3. After step 2, In trending please make sure the following selections are correct to fetch data for the device.
EcoStruxure Power Commission may not required for your requirement. By easy straight forward method you can configure the PM5320 through Panel Server webpage.
Hope it helps!
Regards
Udhayakumar A K
ESXP System Support Expert
  • Thumbnail of EcoStruxure Panel Server Advanced
View products (1)
UdhayakumarAK
Commander
Hello @innoglass
Hope it helps!
Regards
Udhayakumar A K
View products (1)
