PA600L Json Data Realtime With SFTP Server
Gateways and Energy Servers
Select a Country
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • PA600L Json Data Realtime With SFTP Server
Romain_Polette
Romain_Polette Champion
125
Guillaume_Evrard
Guillaume_Evrard Leader
59
Randi_Dolan
Randi_Dolan Leader
46
bedjojaya
bedjojaya
Explorer
Posted: ‎2024-10-25 08:58 PM
2
1220
Hello.
Good afternoon.
Has anyone here ever succeeded in reading data from the PAS600L in Json format in real time using sftp mode?
My SFTP server is correct and normal json with a duration of 10 minutes is saved. but I need json that can read data in real time to manage error reporting.
  • Thumbnail of EcoStruxure Panel Server
View products (1)
  • Building Operations
  • Data Center Operation
  • IT Advisor CFD
  • IT Expert
  • power monitoring expert
Romain_Polette
Champion
Posted: ‎2024-11-05 07:58 AM
Hello @bedjojaya ,
Real time data for downstream devices are only available through Modbus TCP (or Modbus Serial if you set Panel Server in Server Mode).
There is no embedded API to allow real time data access through HTTPS.
SFTP is clearly not adapted for real time data viewing.
Romain POLETTE
Solution Architect - France Operations
sesa64390_bridg
sesa64390_bridg Mentor
Mentor
Posted: ‎2024-10-29 09:11 AM
From my experience with the PaS, for real time-data use Modbus (TCP) to poll the PaS (for the digital inputs) or communicate directly with the meters attached to the PaS (PaS acting as a passthrough gateway and not a data logger) using something like PME, EBO, SCADA, etc.
I'm not sure if the PaS team implemented the ability to directly poll the PaS for any zigbee/wireless connected devices, if not, the old solution was to have a 2nd PaS in a parent-child configuration and then the parent PaS can be polled via modbus for the downstream zigbee devices on the child PaS. There's more info on the architectures in the PaS user guide.
Data export is not real-time, the fastest it can publish logged data is every 10mins. In addition, the json data file needs mapping from the ID's to human-readable names (there's an enhancement request logged for the PaS to export the topology with the json data file to allow the mapping to be automated). The CSV export uses the human-readable names in the data file.
Romain_Polette
Champion
Hello @bedjojaya ,
Romain POLETTE
