EGX100/300 - DeepSea generator controller
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Re: EGX100/300 - DeepSea generator controller
Romain_Polette
Romain_Polette Champion
128
Guillaume_Evrard
Guillaume_Evrard Leader
60
Randi_Dolan
Randi_Dolan Leader
46
Back to Gateways and Energy Servers
nigel_greenwave
nigel_greenwave
Mentor
Posted: ‎2014-02-26 03:54 AM
3600
There has always been a communication problem between a EGX100/300 to a DeepSea generator controller, I'm not sure what the problem is but they just don't like each other?
So what we have been doing over the years is removing the EGX100/300 and installing a Moxa Gateway. This works 100% and also this allows us to have the gen controller on the same power metering bus.
Is anyone else aware of this issue? If so is there a fix on the horizon because we would prefer to install Schneider Gateways than Moxa's?
Replies 11
arjanbijker
arjanbijker Leader
Leader
Posted: ‎2014-02-26 07:39 AM
Hi Nige,
according to my limited knowledge is has to due with the length of the serial frame.  EGX gateway use 11 bits.  Deepsea doesn't use 11 bits serial frame.  This is causing problems w.r.t. gateway functionality.
Anybody with more technical knowledge please share.
Anonymous user
Not applicable
Posted: ‎2014-05-06 03:12 PM
2
3438
Hi Nigel,
We are also finding this issue (with both EGX and also ION7350 as Gateway) communicating with DSE7320. What model of Moxa are you using?
JamesAZZO
JamesAZZO
Leader
Posted: ‎2014-05-06 05:50 PM
We use Moxa MGate 3180s to get around EGX-100/300 issues
nigel_greenwave
nigel_greenwave
Mentor
Posted: ‎2014-05-19 10:28 PM
3438
Hi, we use Moxa Mgate MB3170 is works 100%
ganesh_azzo_com
ganesh_azzo_com
Troubleshooter
Posted: ‎2014-05-20 01:02 AM
Hi Nigel . Would be interested to hear what happens when you say communication issue?
Anonymous user
Not applicable
Posted: ‎2014-05-26 12:52 AM
2
3438
If the issue is due to the serial line frame format (10 / 11 bits),
This should not appears on Com'X 200 (EBX200).
This gateway follows by default the consystency rules of Modbus.org
This rule specifies that frame should always have 11 bits
That is to say that if you specifies the parity, as "none", you must set 2 stop bits.
As it is a =S= rules, the Com'X 200 uses it by default,
as a consequence, if you have configured a Com'X 200 with {8 bits, parity even and 1 stop bit},
and if you change the parity to "none", the Com'X 200 will automatically set the stop bit number to 2.
But afterthat, you can manually set again the stop bit number to 1.
As a summary, the Com'X 200 is compatible by default with modbus.org requirements, but is also opened to 3rd party devices.
arjanbijker
arjanbijker Leader
Leader
Posted: ‎2014-05-26 01:06 AM
Great stuff!
Will they consider this 3rd party support 10 bits for the egx100/300 gateways as well in future?
Sent from my iPad
nigel_greenwave
nigel_greenwave
Mentor
Posted: ‎2014-05-27 03:36 AM
Thanks Jef
Mariani
Mariani
Contributor
Posted: ‎2018-08-02 11:13 AM
3438
Hi all!
I'm having the same communication problem between an EGX100 and DSE7320 even with DSE335.
Exist a way to change the stop bits to EGX100 to make compatible with third party devices in order to solve the problem without to remove the Schneider's Gateway to put another brand?
Thanks to your prompt response!
Nelson Chiquin
Marcos Hennyh
Anonymous user
Not applicable
Posted: ‎2018-08-06 09:14 AM
3438
Hi Adriana,
It is not possible to change the stop bits on the EGX100.
Best,
Colton
Mariani
Mariani
Contributor
Posted: ‎2018-08-06 09:48 AM
Hi Colton!
Could you suggest me the best and cheaper option by Schneider Electric to offer my customer?
We have that problem in two areas, one of them with 1 DSE7320 and another one with 2 DSE335 as you can see into the follow image
Best Regards,
Mariani
Nelson Chiquin​
Marcos Hennyh​
