Connect ION7650 to PME 7.2 using EGX100
Gateways and Energy Servers
  • EcoStruxure Power & Grid
  • Gateways and Energy Servers
  • Re: Connect ION7650 to PME 7.2 using EGX100
Romain_Polette
Romain_Polette Champion
128
Guillaume_Evrard
Guillaume_Evrard Leader
60
Randi_Dolan
Randi_Dolan Leader
46
Back to Gateways and Energy Servers
Anonymous user
Not applicable
Posted: ‎2015-07-21 04:13 AM
1653
Hi All,
I have an issue when I try to connect ION7650 to PME 7.2 using EGX 100 and COM2: there is no data displayed in the EGX100 registers or in PME7.2.
The ION7650 configuration is :
7056
7057
The EGX configuration is:
7055
When i try to read registers in EGX100 i have no values :
7053
The ION7650 is connected with several PM870 to the EGX100 via RS485 liaison.
7049
I can't find where is the problem?
Need your help on this.
Best regards.
sesa186702
sesa186702 Leader
Leader
Posted: ‎2015-07-21 06:48 PM
Hi Amine,
I have checked and found that you should fill the Input address on EGX100 start from 150, not 40150 as you did
By this way, I can read data from ION, no need to configure anything more
7075
7076
7077
7078
Please try again!
Best Regards
Replies 5
sesa186702
sesa186702 Leader
Leader
Posted: ‎2015-07-21 04:26 AM
1585
Hi Amine,
I see your GTW can read data from ION7650 without error. So, the problem if any just in Mapping for Modbus Communication in ION7650
I think you're using the Defult Mapping for ION7650, but someone ( may be factory ) has changed Mapping by update Template for this Meter
First, access to check the Mapping inside of ION7650 by IONsetup
a. Connect ION 7650 to IONsetup via Ethernet port
b. Check in Communication/3rd Party Protocols, choose Modbus Slave tab
7033
c. Choose default profile in Map name column, and click Edit
d. At this step, you can check/re-config your mapping for each parameter....
7058
e. Print-out this Mapping for using later
f. Re-check the Data of EGX as you did above steps
Hope it helps you
Best Regards
Anonymous user
Not applicable
Posted: ‎2015-07-21 04:53 AM
1585
Thank you very much for feedback.
I checked the mapping in the default map, when i try to read for exemple Ia in EGX100 ( 40150 Adress) it still display no value :
7061=
I didn't modify any things in IONsetup :
7063
7064
7062
is there any specific configuration to do in IONsetup ?
Best regards.
sesa186702
sesa186702 Leader
Leader
Posted: ‎2015-07-21 06:22 PM
Hi Amine,
I will test again with real ION Meter and revert to you soon
Best Regards
sesa186702
sesa186702 Leader
Leader
Hi Amine,
7075
7076
7077
7078
Please try again!
Best Regards
Anonymous user
Not applicable
Posted: ‎2015-07-23 06:22 AM
Thank you very much for help.
That works.
Best regards.
